Testing Time
We followed our standard case testing methodology, as detailed in our
previous heatsink and case testing article, and fitted the usual set of hardware into the Silverstone FT01, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz)
Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled
Motherboard: MSI P6N SLI Platinum
RAM: 2x 512MB Corsair XMS2-667
Hard Drive: 1x 250GB Western Digital WD2500 7,200RPM
Heatsink: Asus Silent Square Pro
Power Supply: Xilence XP700 700W PSU
While this isn't representative of current ultra high end hardware, the equipment we use is specifically selected to kick out the maximum of heat inside the case, with a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit. If the Hiper Osiris can cope with this set up, it should comfortably handle anything.
We were a little concerned about the obstruction to airflow posed by the large hard drive mounting cages, but were still interested to see if the positive air pressure cooling of the FT01 could compete with the top performers in our thermal testing.
      Cooler Maser HAF 932
      Akasa Omega - all fans
      SilverStone FT01
      Zalman GS1000
      Hiper Osiris
      Akasa Omega - stock fans
      Lancool K7 Metal Boned
      Lian Li Tyr PC-X2000  - high fan
      Akasa Mirage-62
  °C
Ambient
Case
CPU
GPU
Load Delta T (CPU)
      SilverStone FT01
      Cooler Master HAF 932
      Hiper Osiris
      Zalman GS1000
      Akasa Mirage-62
  °C
Idle
Case
CPU
GPU
CPU Delta T (load)
      Akasa Omega - All Fans
      Zalman GS1000
      Hiper Osiris
      SilverStone FT01
      Akasa Mirage-62
  °C
Ambient
Case
CPU
GPU
GPU Delta T
